Selection script
1078.16 In reply to 1078.14
Hi Marc & Paul,
Marc wrote:
> Maybe it is a known issue but just for the record I found out that you cannot
> assign the equal ( = ) and bracket keys ( [ ] ) to a shortcut as they seem to
> interfere with the scripting language.
Actually I didn't know about this, thanks for reporting it!
What is happening here is the = and bracket keys interfere with the structure of the moi.ini file where the shortcut keys are saved, since [] is used for a [section name] in the ini file, and the = is used for an entry like name=value.
Definitely avoid using these for now, they can trigger some bugs that may kind of mess up your moi.ini file.
Also semi-colon is used as a comment in the .ini file, so that's why that one doesn't work as well.
I've fixed these up for the next release, these characters will be escaped when written to the moi.ini file to fix these problems.
I've also added in the Tab key as something you can assign shortcuts to.
Thanks!
