Selection script
1078.12
Here's a variation on the CycleSelect script mixing it in with Petr's SelectByType script.
To use:
Select an object in a viewport (a brep, curve or point object), hit the hotkey you've assigned
and that type of object will be selected in sequence (once per keypress). If no object is selected first, or more than one is selected, a reminder will pop up; press Done; do a selection and rerun the script.
hotkey CycleSelectByType
Alt+hotkey CycleSelectByType Back
Petr, I tried to work in subobject selection, but apparently it's not currently possible, unless I've misunderstood, anyway nothing I tried worked -
Paul
