Hi Avila,
> If I understood correctly, I should have planned better, not applied the fillet to the details
> around the cylinder before I made the cut I did.
Correct, not if the cut is going through existing fillets and you want to apply a new fillet of the same radius that will now need to cross over the previous fillets.
Generally it's better to apply fillets when you're finished with cuts.
> , what I do not understand is why with a higher value it does not happen, at a greater radius
> these lines should cross each other,
Just luck I guess. There are some cases where the filleter is able to detect bunching and slice out the bunched area and sometimes the bunching may be small enough that it doesn't prevent trimming of the object.
