How to use Groups
10762.2 In reply to 10762.1
> Should the 4 arcs, (or 4 points), be named before creating the group.
There is no rule for this, it's up to your own preference. They can be named before grouping them, or after grouping them, or not at all if you don't have any need to target them individually inside the scene browser.
> Should the group be renamed to "OuterArc". (e.g.)
Same thing here, it's up to you to name or not rename the groups as you see fit.
> When the OuterArc is separated, the +box goes dark, and there is no way to
> delete it, or change it, in the dropdown display of objects.
When the + box for a group goes dark without any +/- being shown that means that the group is empty and contains no objects or other groups beneath it.
The Edit > Separate command does an automatic ungrouping, because if it did not and kept the separated objects inside the same group they would still all select together when you clicked on them making it seem like they were still joined. I guess it would be a good idea for it to delete any groups that are now empty after the separate.
You can remove an empty group by selecting it in the scene browser (click on the right hand side of the line where the selection dot shows) and then use Delete (either press Delete keyboard key or use button on bottom toolbar).
> Sometimes when a group is hi-lighted, the points go yellow, other times corner angles show up. (Inconsistent?)
It looks like there are a couple of bugs with handling point objects that are inside of groups. I'll see about fixing these up for the next beta. It is intended that when a group is selected, all the objects inside it should show as yellow-selected but that's not working for point objects currently.
> Once a group is created, unnamed members remain unnamed, and cannot be named.
Once a group is created, yes unnamed members will remain unnamed and that is by design, creating a group does not automatically change the names of the sub-objects that are now inside the group.
The unnamed objects can be named by selecting them and clicking on the name label in the properties panel, the same as how you name a regular ungrouped object.
> Two unnamed subentries can appear, and the 3rd one cannot be deleted.
Can you post a .3dm file where you're seeing two unnamed children within a single group? It is intended that there should only be one single "Unnamed" label within a group that represents child objects that do not have a name of their own.
> The drop-down display seems to be in strictly alphabetical order by group.
Yes that's correct the Objects section of the Scene Browser displays things in alphabetical order.
