ScaleArray not working properly
hihi I have forgotten something :)
You must draw in your first objects a "single point" !!! Menu draw Curve / more /point
Select your objects + the single Point
Apply the Transform Array
Then Select all Object + Points (except the curve if you have made an Array Curve)
Alt + S and then all works fine :)
EDITED: 30 Oct 2007 by PILOU
