Shortcut to constrain a line to specific degree?
10754.2 In reply to 10754.1
Hi verysame, yes if you want to set angle constraint to say 30 degrees, you can type in:
<30
and push Enter. When you type you'll see your keystrokes go into the x/y/z coordinate box in the bottom toolbar, you don't need to click on it first. If you type a single number in that box it will be the same as if you clicked on the distance constraint box and put in a number and if you use the "<" character in front of a number that will be the same as if you clicked in the angle constraint box and put in a number there.
See here for the different kinds of input you can use in the x/y/z coordinate input:
https://moi3d.com/4.0/docs/moi_command_reference1.htm#__XYZ%20/%20Distance%20/%20Angle
You can also press the Tab key to cycle keyboard focus between the x/y/z input, distance constraint input and angle constraint input.
