EXPORT OBJECTS as separate Files
10752.3 In reply to 10752.1
Hi Alex, also one piece that is not very well specified with this kind of a thing is if you want the name to come from an object name instead of picking it with the file dialog, then what directory should be used to write the files into?
Those other scripts probably have the output directory hard coded in the script. So to use them take a look at the script and see if it has a directory name at the top of it that you should modify to match an actual directory you have on your machine.
