Create clean surfaces/selections when exporting as OBJ
10747.5 In reply to 10747.1
"""""""For example, I want to select this section to put a different material than the body and so on but it would take a lot of time to select every triangle of that selection/edge to have a clean selection of that surface. Is there a workaround?""""""
You can select those areas in MoI "FIRST" and assign it a material and an object name.
These should transfer into your poly app through obj for "selection" or whatnot.
