Is there a way to set circle creation to diameter once and for all ?
10736.1
Hello Michael and all,
As said in the title : is there any way to set the input for circle creation to always be diameter, once and for all across all work sessions ?
Of course I do understand that I can do so temporarily, by clicking the little bent arrow next to Radius to turn the input field to Diameter ; or even, type my diameter followed by /2. But these are just workarounds that do not really adress the issue.
Up until now I was telling myself that the current behavior is fine, but I just had a tableflip moment after realizing that the 3D print I just got off the build plate had a circular hole two times bigger than intended - because I like to model without touching the interface (typing values as I need them), and I naturally typed in a diameter yet again :D This is espacially problematic when working from real life measurements, since calipers naturally work in diameters ... and nuts and bolts are named by their diameter too.
I am currently using 4.0 (dec 2020)
Thanks !
