Dimensions Font Scaling
A few more questions about Text in the Dimensions menu please.
Where is the documentation for Dimensions?
Dim>Text brings up Text options box, with Preset: Default.
Is there somewhere to define more Presets?
The desired Preset would define Font Size as 16,
Scaling: By Model Units,
Height: 0.25 units
The Open Sans font is nice.
Select a created Dim Text, and press Details shows the Object properties.
But entering a second Dim Text reverts to the default settings, as far as I know.
Would creating a new Preset cause the second Dim Text entry to match the first one?
Does the regular old Text command create more or less the same text as the Dim Text?
I could do a little more searching the MoI setups for the answers...
In the Moi ui folder:
I see DimPreset.js (But it is in MoI4 ui folder already...)
I see the AddPreset.htm and AddTheme.htm (Where is the AddPreset button?
I found the Property preset: add preset under Options > Dimensions...
Can the Font Size be set for MyTestPreset property ? Without disturbing UI Font setting? ???
(Looks like yes:-)
Works great!
Thank You
EDITED: 13 Dec 2022 by BEMFARMER
