V5 beta May-22-2022 available now
10706.42 In reply to 10706.41
Hi Frederick,
> Based on my use of MOI most of the time I am going to be manipulating an object, not a group.
I guess I'd ask why put it in a group then if you don't want it to behave like a group?
Maybe you need some other organization method separate from groups like "folders" where you can select an entire folder using the scene browser but when you click on objects in the viewport they will select as individual items.
> Would it be hard to allow both drill-down and "drill-up"?
I'm not sure. It would probably have some difficulty co-existing with other selection mechanisms like edge/face drill in on solids.
If your initial click on a solid in a group selected the solid, then if your next click on it would do "drill up" to target the parent group that would mean you could not drill in to select edges or faces of the solid.
