| Hi Frederick,
 > If possible I would like to see a way of exporting a group as individual STLs, for each
 > object, with the file name composed of the group name and the object name
 > concatenated, perhaps using some sort of user defined pattern. The pattern would
 > allow a tag for the group name and the object name plus other literal characters.
 The group structure is accessible to script so It should be possible to make a script that would do that.
 I would need to see an example file with groups set up and the corresponding desired output to make sure I understand what it's supposed to do and you would need to specify in more detail how the user defined pattern would function.
 Also if the file names were generated in this way how would you want to specify the directory for where to place the files, would that be expected to be in the group name?
