How do I shell an open box?
10705.6 In reply to 10705.1
Hi Markog, in the attached version I've opened up that little bit of space in between the flaps by copying edge lines and using Edit > Trim and also cutting out the margin in the corners as well.
With this setup you should now be able to shell the whole thing ok, set Shell thickness = 0.05 and set Direction: Flip.
The spacing helps to keep the flaps from running in to each other.
