wrench
10693.5 In reply to 10693.1
Then when you put on fillets as the last step, I used Edit > Trim to cut these edges to make it easier to do the variable radius fillet:
Then when you fillet the top faces (for filleting here just select top 5 faces, quicker than selecting edges), you start with the small radius and then add a point set at these points and use a larger radius for those:
