wrench
10693.4 In reply to 10693.1
And you can get the same result directly from just curves by making the top/bottom 3 level lines into a closed curve and then using boolean intersection between the 2 closed curves like this:
If you set it up like that it will be easier to make adjustments on the profile curve and quickly get the combined result with just one step.
