wrench
10693.2 In reply to 10693.1
Hi Mario, transitions can tend to be the most difficult area to model, especially when they need to be more gradual and seamless.
One thing that can help is making a kind of larger and more fundamental transition in overall extended surface form rather than finishing separate individual chunks and then trying to fill in seamless connections afterwards.
So for your case here one "seamless" area is you want a transition between these 3 planes:
So if you take a step back and think about the simplest underlying form that could make that full shape, it could be something like this, here modeled with 3 lines with blend curves between and then extruded:
Then when you extrude up the full outline in the Top view you'll be able to use boolen merge to cut all the pieces against each other and extract the core.
