Cutting small cavities into an object
10691.10 In reply to 10691.9
Hi MRAKGR,
> I've run into problems with booleans a few times today, and indeed, extending the cutter
> a bit did solve the issue.
Also what version of MoI are you using? There are some tune ups to booleans in the v5 beta.
I have not been able to test if those changes are significant for what you are running into
since you have not posted any model files.
> But if intersect just gives curves what use is it for booleans? For a boolean of two solids
> wouldn't you need an intersecting surface instead?
The booleans use the intersection curves to partition the 2 solids into different chunks of
connected faces and then those chunks are either combined with others or discarded
depending on what volume they are contained inside of.
