How do you match MoI3d grid settings to Maya 1 to 1?
10690.13 In reply to 10690.11
When dealing with real life hard surface objects, such as mechanical components, I often have to use mm. So switching to cm wouldn't be a good option. And with my current workflow when I create larger pieces of an environment set, such as walls and structures, I often have many different pieces inside the same file. So, having the grid extend to these pieces, is very important since I don't only focus on one piece at a time in the same scene. In most other packages, extending the grid so that it is available when focusing on other elements in the scene, has never been an issue. I understand of course that this is probably not the way that MoI3d was intended to be used. Just sharing my personal experience with it, for your consideration.
Thank you.
