Sketch curve resolution
10682.2 In reply to 10682.1
Hi routb3d,
> Anyone know of a script that I can use to set the resolution of a sketch curve?
There is not currently any way for a script to adjust this, can you describe a bit about
what you're trying to do or what problem you're seeing?
> Also, the repeat check box in the sketch curve ui is missing in version 5 beta, and I'm
> assuming it has been replaced by some other method. Anyone know anything about this?
Hmm, no it's not intended to be missing or replaced by anything else and I can't repeat the
problem of it not showing over here on 3 different machines.
What OS are you running on, and have you done any customization of the UI perhaps?
