Small dimensions
10673.3 In reply to 10673.1
Hi Gaston,
> Is it also possible to move (float) the text of small dimensions so they can
> be positioned more conveniently?
Yes the text of a dimension can be repositioned to anywhere you like.
You do that by selecting the dimension and then click Edit > "Show pts".
An edit point will appear at the text location and you can drag that point to change the text position.
If you want it to go back to being auto positioned, select the point and push Delete.
