How to join multiple lines into a grid
10669.2 In reply to 10669.1
Hi hmc, it isn't necessary to make a single object out of your lines. You can flow any number of objects, just select them all as input into the Flow command.
Curves are a path-like object with a start and end, you can only join a curve to another curve that is touching it at their endpoints to make a longer path.
So you can't join curves together into a single curve object in the type of configuration that you are describing, but you do not need to do that to flow them either.
