V5 Beta test
10653.70 In reply to 10653.68
Hi Cuboctahedron,
> Also, in the dark theme, the selection rectangle and construction lines are pretty hard
> to see if you also have a darkish background color. It would be nice to have them
> tweakable without a full theme swap.
Can you please post a screenshot of what you're seeing?
When you have a dark background, the construction lines should display as alternating dark and white to make them easier to see. That should change from the regular light mode display where they are drawn in a dash pattern of color / transparent / color / transparent etc...
It's generally best not to have a really pitch black viewport background because then files that you open with black lines in them will be very difficult to see.
