Hi Psygorn,
> Nodeeditor located here: "C:\...\AppData\Roaming\Moi" that's why I expected it to work with V5 as well.
Yes, if it's being used from there it should work in both v4 and v5 as well.
> The short key I use for it in V4 is: Alt+N
Can you also post the text you have for the "command" part of the shortcut key?
