Thank you for your help, however, I have got a few questions for you:
>Things that you add to the central appdata folder will be seen by new versions automatically.
That's so you can do things like install plug-ins there and not need to copy them to individual
install folders with new program releases.
Is it possible to have Moi discovers startup settings automatically?
> The other options you could do would be to apply the same browser pane mod to the v5
beta so the scripts would be able to find what they are expecting there too
By doing above mentioned solution Moi V5 beta would have the same UI settings as Moi V4? Do I have to do things manually In order to apply the same browser pane mode to the V5 beta? Is there a way I can have it done automatically? And basically, tell me how to do it!
-Psygorn
