You're right. It's not a big problem…
No need to have a patch yet.
import/export SVG file.
Very good idea to have this possibility.
I export a square (from MoI) 10x10 mm (on floor plane centered at origin) into SVG.
When I import it, it's not at same place. Strange but understandable.
But the dimensions are 10x3,05 mm. More a problem.
I open this file with MsEdge. it seems to be a perfect square.
If I open it with a notepad, the definition is a polygon which describe a square with the right proportionnality.
I think the problem is in import SVG function.
