Update mesh export vertex normal combining. Change vertex normal combining to use tolerance of 0.5 degrees instead of 3.0 degrees. It can also be changed now in moi.ini .
[Mesh Export]
UnifyVertexNormalsAngleToleranceDegrees=0.5
Hello. I have been using Moi3D to convert SolidWorks>STEP>Moi export OBJ and when you get into Blender you have to use the merge command to merge vertices which are never combined. Does this remove the need to do this? In Blender merge is done by distance, so I am not sure if angle changing will fix it.
