Automatically select last created object(s) when the operation ends?
10650.3 In reply to 10650.1
Hi Flowgun,
> * nothing else is selected during creation: no issues - just select the newly created one. this
> doesn't interfere with other cases at all.
But the problem is that it does interfere with things in subtle ways.
Here's a simple scenario - you want to draw in a line with the intention of using it as the cutting object in boolean difference.
But boolean difference doesn't just work on a single selection, it needs 2 separate selections, one for the base objects and then a second selection step where you give it the cutting objects.
If a newly drawn line was selected automatically you now need to do an extra step to deselect it before you can run boolean difference because it needs to be selected as a cutting object not as a base object.
It's just not the case that it would universally be helpful to alter the selection like that.
