Hi Al, my guess would be that your file is made up of either Mesh objects or block instances.
If you select one of the objects that won't import and use the "What" command in Rhino, what does it say about the object?
If you can possibly export a small fragment of that large file to a smaller file, maybe you could send that to me to check out at moi@moi3d.com .
