HELP WITH NODE - OBJECT TWIST CONTROLLED BY INPUT CURVE
10649.4 In reply to 10649.1
Hi Alex, it's probably going to be very difficult to do that with a solid as the input object to be deformed.
What could work is if it took a cross section curve as the shape input and then copy and rotate the cross section curve and Loft them to make a solid. Would that produce a result like you need?
