HELP WITH NODE - OBJECT TWIST CONTROLLED BY INPUT CURVE
10649.3 In reply to 10649.1
Hi Alex.
First of all do the Flow manually.
So the first thing to do is to rotate axis your input object by 90 degrees, using the straight control curve (base curve) as the rotate axis.
Then FLOW the input object, using the base curve straight line, and use the wavy line as the target curve for the flow.
Stretch may be used.
The input object seems to be too short...
Then do the nodes.
The base line is not in the center of the input object, so direction of 90 degrees might make a slight difference?
