FR Button to toggle snap to locked objects.
10648.2 In reply to 10648.1
Hi Dodgy, you can set up a keyboard shortcut to do that.
Go to Options > Shortcut keys and push Add.
After setting the key you want to use, put this in for the Command part:
script: /* Toggle snap to locked objects */ moi.drawingAids.snapToLockedObjects = !moi.drawingAids.snapToLockedObjects;
Then you should be able to push that key to toggle it without needing to go into the Options dialog.
