Draw/Edit Rectangles from center
10647.6 In reply to 10647.5
Hi moritz,
> > "But when you click on the Rect button, the 2nd icon should be launched for the
> > initial default instead of the first one."
> I can live with that.
So is that part working for you ok? With the change to the ordering in Rectangles.xml do you get rect from center as the default?
If you wish to change the order of the buttons that is possible by editing Rectangles.htm . The .xml file defines what commands are in the "command set" and the first one there will be the default one that is initially launched when activating the command set. The .htm file has the UI that is displayed for that command set.
