Draw/Edit Rectangles from center
10647.4 In reply to 10647.3
Hi moritz,
> But when I started the program, the position of the symbols didn't change.
It's normal that the position would not change. But when you click on the Rect button, the 2nd icon
should be launched for the initial default instead of the first one. This is what it looks like over here:
If it's not working for you like that over there what happens if you disable the UI mod in your startup folder that's
modifying the side pane UI, does it work then?
