script error
10629.5 In reply to 10629.3
Hi Matt,
> Im a bit confused - do these scripts go here:
> /Applications/MoI v4.app/Contents/Resources/commands
> or here
> ~/Library/Application Support/Moi/commands
Starting with MoI version 4 it will look for commands in both the program's command folder (your first one above) and additionally in the appdata commands folder (your second one above).
Either one should work but it is recommended to use the appdata folder since that is in one central location outside of any specific app bundle and so stuff put in there will be found by new versions without any need for copying files around.
> I moved all my commands over to the latter folder and now they don't work . . . .
What's an example of one that doesn't work aside from this bolt one? There are usually 2 files, a .js and and .htm file is it possible you only moved one of them?
