Convert model from perspective to front view
10626.24
Hi BurrMan,
I just realized that we still have to work around the scaling (please forgive my English): so, for the arches, the nearer it is then the wider it should be. i.e.: the leftmost arch should be the narrowest compared to the others, and the rightmost should be the widest. I believe that I have to flow-deform the model once more (after narrowing the leftmost part) to achieve this... One step at a time.
Hi Michael.
That's very close to what I'm trying to achieve, expect for it to become a relief, the 'back part' of the model should be flat and aligned to the origin axis like so:
Please focus on the front and right views. All of its parts need to be extruded (based on the current Top View) along with the Z axis to the construction plane. So, the final model should be a single solid which qualified to be called as relief (that's what my 'client' said, and he is my little brother ^^)
Oh, and it is great if such a feature is added to the V5!
Thank you very much guys, for your help and attention.
EDITED: 27 Mar 2022 by ELANG
