Extrude question
10613.2 In reply to 10613.1
Hi Tom, when you are in the "Pick extrusion point" step of the Extrude command, if you move your mouse around in the viewport you will see that the distance is updated with every mouse move.
That's the difference between Extrude and Chamfer as you were comparing. In Chamfer the command does not go immediately into an interactive mouse mode where the value is being updated with every mouse move, while Extrude does.
