Multiple Isolation levels
10598.2 In reply to 10598.1
Hi Kash, try these - go to Options > Shortcut keys and for the isolate shortcut key put this in to the Command section of the shortcut key:
script: /* Multi-level isolate */ var states = []; var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); states[obj.id] = obj.hidden; if ( !obj.selected ) { obj.hidden = true; } } var levels = []; try { levels = moi.command.getOption( 'multi-level isolate' ); } catch(e) {}; levels.push( states ); moi.command.setOption( 'multi-level isolate', levels );
And for your unisolate shortcut key put in this:
script: /* Multi-level unisolate */ var levels = []; try { levels = moi.command.getOption( 'multi-level isolate' ); } catch(e) {} if ( levels.length > 0 ) { var states = levels.pop(); moi.command.setOption( 'multi-level isolate', levels ); var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); var state = states[obj.id]; if ( state != undefined ) { obj.hidden = state; } } }
