Display and Export problem
10589.1
I have an object that displays "inside lines on the outside".
Worse yet, the lines also export, when exported to Illustrator.
First I thought it might be a meshing-angle problem, but even when set to one the problem persists.
If I cut that object horizontally in half, the problem disappears, when re-unioned, it shows up again...
I have no idea on how to fix that.
Attached an image of the problem. The rotated view also shows other artifacts, they also export
Hope there's a solution,
Thanx!
EDITED: 14 Feb 2022 by DEATH
