Actual 3d patterns and problems with boolean difference
10587.1
Hello everyone
Is it possible to make a simple 3d pattern on a flat surface? Such as this one: https://previews.123rf.com/images/irynaulbutova/irynaulbutova1502/irynaulbutova150200011/36474081-white-seamless-3d-background-with-dots.jpg
The one I'm looking for is basically a pattern made of half spheres (kinda) with one half sphere very close to the other and quite small. Is it possible to do it in a different way than placing manually each sphere in place?
Another pattern is a "grainy" pattern so that when the object is printed has areas that are a bit "grainy" and others that are smooth
Another problem i have is that the boolean difference doesn't work. I have this 3d object made in moi3d and I want to make a mold from it, so i create a 3d rectangle (bigger than the object and higher) and the idea is to subtract the object from the rectangle so it leaves an impression inside. That should be theoretically possible but I'm not able to do it, the software takes some time to process the action then nothing happens.
Thank you very much for any help! The software is great
