How to close to make solid
10586.8 In reply to 10586.5
Hi Matadem, so on the "no split.3dm" file your geometry looks all good and ready to go, you were almost done. you probably just need to avoid getting that additional surface involved in the booleans.
Try these steps:
1. Hide all curves so they aren't getting in your way. Click here:
2. Hide that open surface by clicking just below on Types > Surfaces:
3. Select all the objects, it should say 24 solids are selected:
4. Run Construct > Boolean > Union, those should all combine into one single solid:
You can now draw a line and use it as the cutting object in boolean difference to slice it in half if you want.
Let me know if you still have trouble.
