Flip script and height bump/map script
10578.8 In reply to 10578.6
10578.6 In reply to 10578.5
I hope Michael makes sequential shortcuts as soon as possible! That would be awesome!
Imagine u press "F" for Fillet and then "C" to get Chamfer!
This way I guess we could do define sequential shortcuts for flipping along vertical and horizontal lines. (it's just a thought)
I myself use "M" to do the mirroring. I thought it could be awesome if I could define sequential shortcuts within MoI like "M"+"X" mirror along X-axis. "M" + "Y" for mirror along Y-axis
Yes something like this I was thinking
On the Fillet and chamfer topic I always thought It would be nice for instance if you are in the fillet command with your lines or your items selected
That shows you the fillet numbers range that would work, example between 5mm and 50mm ...outside the range it would be a calculation failed.
This is what I came up with some simple testing
this was created from a simple black and white image with the Zsurf extruded in Moi. Boolean merge bottom.
However when I tried Boolean merge or trim the top it would be hollow. So I made a cube and Boolean diff the top.
Size: 365.7 KB, Downloaded: 59 times, Dimensions: 875x581px
