Flip script and height bump/map script
10578.3 In reply to 10578.1
Hi Matadem,
> Does a script exist where you can quickly flip your item horizontal and vertical?
> so this can be configured with a shortcut
There isn't any existing script for this that I am aware of.
You can use the edit frame corners to do a quick mirror of an object though, if you grab a corner and move it to one of the other corners:
> Is there a way to recreate the black texture in Moi or close to
> it > https://www.brandinginasia.com/wp-content/uploads/2015/06/Datsun-Logo-history.jpg
Max has made a HeightMap plugin that can do that:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7547.1
It's in his file archive here:
http://moi.maxsm.net/media/files/
There is also a free standalone program called ZSurf that can do that type of thing, some links here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2423.2
However, CAD programs are generally not suited to work with surfaces that have high frequency bumpy details like that in it, it is much more efficient to have that done as a bump or displacement shader in a rendering program.
