Flip script and height bump/map script
10578.13 In reply to 10578.8
Hi Matadem,
> On the Fillet and chamfer topic I always thought It would be nice for instance if you are in the
> fillet command with your lines or your items selected
> That shows you the fillet numbers range that would work, example between 5mm and
> 50mm ...outside the range it would be a calculation failed.
Unfortunately it would require quite a lot of number crunching to figure that out. Probably some kind of specialized solver for intersections between offset surfaces would be involved.
So there would probably be some kind of long 10 minute hiccup when you started the Fillet command before it would have that information and be able to proceed with the command.
