Fillet and Flow problems..
10577.2 In reply to 10577.1
@koi
I tried to create the sunglasses as told in the tutorial "sunglasses 3D with flow" on YouTube. When I made the second flow, my frame got twisted. Unfortunally I don“t know why and how to solve it.
Hi koi :)
That's not a tutorial but a workflow that show one of many ways to get a shape like that
It doesn't mean that work for all sunglasses...that's obvious
some suggestions:
-draw sunglasses ? set units to millimeters not centimeters
-draw lines as clean as possible using less points you can
-draw a simmetry line guide and use it as reference ALWAYS !
-if you need more points,use rebuild points function before extrude,it will avoid unwanted seams on your solid,difficult to fillet
-you can't expect to fillet everything,everytime,you must have good conditions for filleting
I did a try on your file
rebuilt lines and flowed the frame using line to line option
if nose area is too large,move flow noise line points closer to simmetry line
if it's not enough,draw a lower nose frame area
file attached below with all steps
take a look at the points of the lines i rebuilded and cleaned
Here is 11years ago original post...and still here :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=4471.1
M
