Hi NaN, Network is looking for a boundary made up of 4 separate curves, not just one single closed curve like you have here.
So you'll need to use Edit > Separate and then Edit > Join on your curve to form 4 separate curves like in the attached file and then Network will be able to use it.
Construct > Planar won't work on it because the whole curve is not all on a single plane.
