whale
10568.6 In reply to 10568.3
Hi Mala, I'm not sure if this is what you need but it is possible to use Construct > Curve > Silhouette to make a mold "parting line". You can remove an area of undercut with it.
Construct > Curve > Silhouette can generate these using "Top" as the projection view will generate these curves:
Trim the surface with the silhouette curves:
Project the silhouettes and extrude the projections:
Trim extrusions:
That will cause the shape to drop straight downwards with no area "in shadow" :
EDITED: 28 Jan 2022 by MICHAEL GIBSON
