whale
10568.2 In reply to 10568.1
Hi Mala, re:
> Perfect would be if the hand attached would not come in at the near of the ring.
I'm sorry I'm not understanding this part. Is it that you want it positioned more towards one side of the ring surface?
One thing that could be good to try is calculate the length of this curve here:
You can do that by selecting it, then push "Details..." :
And on the detailed object properties push the "Calc" button to calculate the length. You can then click on the length label to copy it to the clipboard:
Use that distance for the height of your plane to get a closer proportional match between the plane and the bent surface.
When doing the flow click on these spots to control the matching between them. Notice it's not right on the corner, it's a little distance away from the corner along one edge:
Or also spots like this would work too, again the key thing is not exactly on the corner, it's a little distance away from the corner along one edge. Not exactly in the corner and not exactly halfway between 2 corners.
