Make 2D 4 view
10551.7 In reply to 10551.6
Hi Chri,
> the 3D view is the current view when calling the script
> ( and not a parallel or isometric view )
Yes that's how it is set up to work, same as the regular Make2D command and also same as the Make2D command in Rhino as well.
If you want it to generate a parallel view you need to set the 3D view to be a parallel projection before running this command.
