circular gear with a linear gear
10548.12 In reply to 10548.11
Since we were talking about gears, I wanted to look for any input on "Planetary/Inside ring gears.
When looking at images and online stuff, I cannot find anything referencing this.
My question is, shouldn't the tooth profile be "Inverted" also?
I see everybody do just a negative to get the outer ring. Maybe if the outer ring is STATIONARY and only provides a rotational constraint to all the inner gears.
There was an update made to the gear script for "Inner" where he mentions he just reverses the addendum and dedendum to get clearances...
But if the outer ring rotates, the teeth should also be inverted? (See image) To maintain the designed "Pressure Angles" and such.
As I type, I think maybe the outer ring is always meant to be "stationary" in its function? (Lack of understanding on my part)
Anyway, Any enlightenment is welcome..
