3Dconnexion CadMouse radial menu issue
10543.4
Thank you very much for your help! It seems I've got the viewport portion taken care of, and with all the shortcut arrangements available I should be able to work out something that will fit my needs. It took a while to do the macros, but since moi.ini can be easily backed up and 3DxWare driver settings can be exported, I only need to do everything once.
